Vortz Airbox fir Twin HS4s
I have a Vortz airbox for use on my 72 GT running twin HS4 carbs, it is undergoing a full restoration and was wondering if anyone had any experience on which air filters to use, it has trumpets in the housing so I guess foam or circular, as the air intakes are on one side i was thinking a domed foam may be better as circulars may restrict air from the inlet tubes reaching the far carb?
- Has thanked: 7 times
- Been thanked: 22 times
Re: Vortz Airbox fir Twin HS4s
Here’s a snap from the Vortz book of Nick working on a set of carbs.
You can see he used foam around the edge of the box with a foam partition in the middle leaving a square opening around each bell mouth.
I don’t know where you would be able to get the correct type of filter material though?
Great pic there and something to look at, thank your fur the foam filter link too
