Any handbrake triggers that fit?
Bitsilly
Post by Bitsilly »
I am supposed to have a signal for my control system that tells it when the handbrake is on.
Before I try and reinvent the wheel, does anyone know if there are perhaps later model mini handbrake switches that fit?
Or otherwise?
Ed
mini1960
Re: Any handbrake triggers that fit?
Post by mini1960 »
Hi,
the Innocenti Minis had a switch and a control light.
The hand brake lever was different from the English models.
I‘ll try to get a picture later.
Regards
Daniel
Looking for Morris Mini Minor 1960 parts... (master brake and clutch cylinder, lower dashtray panel)
Richspec
Post by Richspec »
didnt metros have a switch on them, I seem to recall robbing one off a breaker many moons ago and thinking ' that might come in useful'.
God only knows where it went...
mini1960
Post by mini1960 »
Hi Ed,
this is the Innocenti part...
Best regards,
Daniel
Bitsilly
Post by Bitsilly »
Thanks gentlemen
I should be able to knock up something similar, maybe with a door switch type.
olddave
Been thanked: 12 times
Post by olddave »
Or a stoplight switch?
Has thanked: 138 times
Been thanked: 116 times
The late and readily available MGB handbrake warning light switch looks like an easy fix to a mini handbrake lever.
Stopped-again
Post by Stopped-again »
Hi there, I might have an Innocenti switch in my lock up, I’ll have a rummage around tomorrow and let you know.
Stopped-again
Me again, sorry looked everywhere can’t find it.
Craig
Post by Craig »
Mid to late 70s Canadian cars had a switch on the handbrake. I think it had something to do with a warning buzzer behind the dash
Sure it could be used for other applications .
Craig
