valve spring
sanm72
valve spring
Post by sanm72 »
Hi!
Please, I have a question for all the engine Cooper S experts.
Introd: My 1275 MK1 Cooper S engine was bilt using the METRO MG Cam.
Question: Is it correct to use the standard 160lb double valve springs (7000 rpm limit) or is it more desirable to use the fast road 200lb springs?
Many Thanks
Sandro
Austin Mini Cooper MK1 66'
Inno Mini Cooper MK2 69'
Inno Mini Cooper MK3 71'
Vegard
Re: valve spring
Post by Vegard »
The MGMetro cam won't rev more than 7000 anyway. Use the softest springs you can get away with. Remember to check the fitted length.
