Rubber sleeve for brake lines under the car..
gs.davies
Has thanked: 72 times
Been thanked: 69 times
Post by gs.davies »
Any work arounds for this that don’t involve £1.15 for each piece..?
https://www.somerfordmini.co.uk/sleeve- ... protection
GraemeC
Re: Rubber sleeve for brake lines under the car..
Post by GraemeC »
Suitable ID hose cut to length and split?
https://www.advancedfluidsolutions.co.u ... -594-p.asp
65MK1S
Post by 65MK1S »
Just purchase some hose that the dia is a little smaller
than the tubing, cut lengthwise and fold over tubing. I used
three different sizes for my car, one for hydro, one for gas and
one for brake. What GraemeC said :)
This is the hydro line but it's all the same.
bwaminispeed
Post by bwaminispeed »
I may be wrong (quite often am), but, I think the nylon sleeves were on the hydro lines only......
Don't think the brake and gas lines had them.......
65MK1S
Post by 65MK1S »
bwaminispeed wrote: Mon Nov 08, 2021 7:46 pm I may be wrong (quite often am), but, I think the nylon sleeves were on the hydro lines only......
You're probably right, I just didn't want to look for a rattle
after I got it all put together :) I hate rattles :evil:
360gts
Been thanked: 53 times
Post by 360gts »
The brake lines were fitted with thin sleeves...most likely prior to the flaring on the ends were done. Shrink tubing works ....use the thicker wall shrink tubing. Just position the pieces (approx.1" lengths) where you want them and a gentle warm with a heat gun ensures permanent position.
Unfortunately, can only be done before you install the lines.
gs.davies
Post by gs.davies »
Thanks all, some good suggestions here. I'll get hold of some pipe and open it up - not like this is going to be on display after all!
Ronnie
Has thanked: 12 times
Been thanked: 30 times
Post by Ronnie »
Or you could use this > https://uk.farnell.com/pro-power/ks6n/s ... dp/1416082
Available also eBay. ;)
winabbey
Has thanked: 5 times
Been thanked: 15 times
Post by winabbey »
On Australian built cars the brake pipes had a short split rubber sleeve, part 6K751. They just slipped over the pipe in appropriate spots where rubbing could occur.
The hydro lines had a split green sleeve cut in a diagonal from nylon tubing so it wrapped around the pipe and stayed in place.
Nothing special with either sleeve so alternatives should be easy to make.
