ARP rod bolt torque
360gts
Been thanked: 53 times
ARP rod bolt torque
Post by 360gts »
Trying to find the torque setting on ARP rod bolts on an S engine......
Quick response please.
Craig
Re: ARP rod bolt torque
Post by Craig »
Email sent Dermott …..
Craig
360gts
Post by 360gts »
Thanks Craig.
I phoned ARP earlier today....they were not very helpful....said they did not supply the bolts!!
Dug around and discovered these are ARP bolts but sold by Mini Mania in California.
Phoned them...unlike ARP...were very helpful.
Here is what they suggest.
55lbs using regular oii as a lubricant...46 lbs using the ARP lubricant that is supplied with the bolts.
That is the same as stated in the BMC workshop manual for S rods.
I went with the 46lbs.
whistler
Has thanked: 18 times
Post by whistler »
From what I understand ARP bolts should tightened down using a stretch gauge not a torque wrench.
iain1967s
Post by iain1967s »
Previously discussed by Spider, with a copy of the ARP sheet:
http://mk1-forum.net/viewtopic.php?p=181750#p181750
Ronnie
Has thanked: 12 times
Been thanked: 30 times
Post by Ronnie »
whistler wrote: Sat Jul 31, 2021 9:44 am From what I understand ARP bolts should tightened down using a stretch gauge not a torque wrench.
Nothing new there then, the same as ABINGDON in the 60's and GEC Paxman. 8-)
winabbey
Has thanked: 5 times
Been thanked: 15 times
Post by winabbey »
I have heard about rod bolt stretch gauges but never seen one being used, or even seen an example of the instrument itself.
For those in a similar boat to me this simple straightforward explanation and demonstration of its use was of interest.
https://www.youtube.com/watch?v=uqjHdKkurXs
whistler
Post by whistler »
winabbey wrote: Sun Aug 01, 2021 3:26 am I have heard about rod bolt stretch gauges but never seen one being used, or even seen an example of the instrument itself.
My friend has and uses one for his hill climb car. Think it came from ARP or Arrow, not sure.
Hipwell
Post by Hipwell »
That’s true but even more importantly, the rods should always be resized after fitting the bolts.
