Overrun
Overrun
Just getting the final bits done on the historic lookalike, when I have been out in it and turn the engine off I get overrun/ dieseling. Is there a fix to stop this or something I have to get use to? It has just been tuned on a rolling road, is there something they could have done to prevent this?
- Been thanked: 15 times
Re: Overrun
I have fitted the anti overrun selonoid valve from a metro before when I had this problem, that goes to the inlet manifold. Turn the engine off and it opens letting a load of air into the engine
- 111Robin
- Been thanked: 17 times
Re: Overrun
I generally just blip the throttle and as the revs drop off below idle speed (before rising back up) turn off the ignition. Seems to work but not necessarily on every car.
- Has thanked: 138 times
- Been thanked: 117 times
Re: Overrun
I haven't got the answer as I haven't got the car in front of me so I'd be guessing. But fitting an overrun valve or blipping the throttle are palliatives and not cures. Surely the answer is to find the fault - excess fueling - and cure that somehow.
Later MGB's had an overrun or a gulp valve(?) fitted to cure a carb problem but this was easily sorted out
Re: Overrun
HOY did that so Dad suggested ignition may be a bit retarded (set up static). Turned distributor gnats cock to advance and it’s cured it.
I did have to re-fit the anti-run on valve to an MG Metro engine I fitted in a Mini years ago, as that was the only way to stop it running on.
- Has thanked: 12 times
Re: Overrun
agree with Peter no point in a palliative action
Would be looking for the cause most likely culprits incorrect ignition timing or incorrect carb mixture
Mini's only run on when something isnt right
Cant comment on newer emission equiped mini's though
Re: Overrun
To far advanced genrally cause's a run on or a weak mixture.Andrew1967 wrote: ↑Tue Jul 27, 2021 9:33 am HOY did that so Dad suggested ignition may be a bit retarded (set up static). Turned distributor gnats cock to advance and it’s cured it.
Thats what i was taught many years ago
I may have forgotten though as it has been many years since i made a living from engines
Re: Overrun
If your plugs are healthy colour not running to leanAndrew1967 wrote: ↑Tue Jul 27, 2021 1:52 pm I may have got it wrong Nick![]()
I turned distributor very slightly clockwise ….![]()
Try retarding it you may be able to do away with metro anti run valve thing
Re: Overrun
What compression ratio does the engine have, as you may get overrun if the compression ratio is too high for the fuel octane rating.
Re: Overrun
I used to get it after a hard run in Redshed. I’d let it idle and if needs be stall it on the clutch.
- iain1967s
- Been thanked: 7 times
Re: Overrun
MG Metro needed the anti run-on aka decompression valve because of the heinously aggressive vacuum advance, caused by taking it directly off the manifold instead of from behind the carb butterfly. Keith Calver wrote an article about it a few years ago.
https://www.calverst.com/technical-info ... e-take-off
Re: Overrun
Interesting article how a small thing like moving take off make such a dramatic difference.iain1967s wrote: ↑Tue Jul 27, 2021 2:44 pm MG Metro needed the anti run-on aka decompression valve because of the heinously aggressive vacuum advance, caused by taking it directly off the manifold instead of from behind the carb butterfly. Keith Calver wrote an article about it a few years ago.
Re: Overrun
nick@dunsdale wrote: ↑Tue Jul 27, 2021 2:10 pmIf your plugs are healthy colour not running to leanAndrew1967 wrote: ↑Tue Jul 27, 2021 1:52 pm I may have got it wrong Nick![]()
Try retarding it you may be able to do away with metro anti run valve thing![]()
I will check plug colour to see how HOY is running but the anti run on valve was on a Mini long since gone.
Re: Overrun
I had it on my mk2 but as above a small alteration in ignition timing stopped it and also made it run cooler,
Pretty sure I had timing to retarded, I also use Bp7es plugs compression is 9.8:1
- mab01uk
- Has thanked: 238 times
- Been thanked: 211 times
Re: Overrun
The 1990-91 Carb Rover Coopers also had the Metro type anti run-on valve bolted to the Servo support bracket.iain1967s wrote: ↑Tue Jul 27, 2021 2:44 pm MG Metro needed the anti run-on aka decompression valve because of the heinously aggressive vacuum advance, caused by taking it directly off the manifold instead of from behind the carb butterfly. Keith Calver wrote an article about it a few years ago.
https://www.somerfordmini.co.uk/catalog ... 774_100818
Re: Overrun
The car I had it on was in the early 90's, and probably everything that we know is wrong now I did to it
Those were the days
