Bleeding braking system using an Easybleed kit.
Cammsjb
Post by Cammsjb »
Has anyone managed to bleed the braking system fitted with a standard 'S' servo using an Easybleed kit and achieved a high solid pedal, I have tried twice but there's no pedal pressure until its just above the floor, if I pump the peddle the pressure improves slightly.
The car is fitted with new shoes and pads.
Daz1968
Re: Bleeding braking system using an Easybleed kit.
Post by Daz1968 »
I can’t comment regards servo, but I used one on my 998 Cooper for brakes and clutch and found it very good, only thing I did was use the bottle empty so I only used air pressure, this meant I checked it after each wheel was bled, I didn’t want to risk it’s auto fill of master cylinders
floormanager
Has thanked: 20 times
Post by floormanager »
I've used it successfully, with no issues.
Paul
timmy201
Been thanked: 39 times
Post by timmy201 »
Are you still getting air out of the bleeders?
I assume you have the rear drums adjusted properly? The brake pads are tight against the discs?
Exminiman
Has thanked: 54 times
Been thanked: 52 times
Post by Exminiman »
floormanager wrote: Thu Jul 08, 2021 10:04 pm I've used it successfully, with no issues.
Paul
Ditto
GraemeC
Post by GraemeC »
I always do one end at a time with the Eezibleed.
Open both (front or rear) nipples, then connect the eezibleed to the tyre, then close the nipples as they run clear and bubble free.
Exminiman
Post by Exminiman »
GraemeC wrote: Fri Jul 09, 2021 6:50 am I always do one end at a time with the Eezibleed.
To be honest all I have ever done is furthest first, one by one, we used to pump tyre up a bit more to get a bit more pressure.....occasionally.
Polarsilver
Has thanked: 38 times
Post by Polarsilver »
Why not bleed your system without the Easybleed .. start furthest away from the master cylinder & work through .. top up with fluid every 10 or less Pumps .. see how you get on... use a glass jar / bottle to look see what if any air is pushed through during the bleed
Is the Servo mounted in correct phase & what type of Brake Fluid is being used .
Also re-check All the brake pipe union/joints / cylinders for weep loss of fluid.
IF all then is not the Fix By-pass the Servo & re-Bleed the Brakes ..do you then have brake pressure without any Servo in the system ?
Cammsjb
Post by Cammsjb »
Thanks to you all.
I will work through all the comments.
Used Dot 5 fluid, all brake system pipes/parts are new, the servo has been stripped down serviced & reassembled by specialist & refitted as original.
Should any air in the servo purge out whilst beading the brake cylinders at the 4 nipples?
John
johnv
Post by johnv »
We had trouble with the servo system as well .. solved by using both methods at once! Traditional pump release with the easibleed connected. It could also help to put a bleed nipple on the nose of the servo first and bleed it through
Mk2 1968 Cooper 998 TPL555F
Mk1 1965 Cooper 1275 BFC110C
