Anybody happen to know how long the line from the clutch master
cylinder to the slave union is on a left hand drive car? This line was
missing from the "kit" I purchased
Kent
Although, I have found a few mistakes in the AKD books as regards lengths indicated......
Just to check, I take a piece of solid 12ish gauge copper wire, and, bend up the one I am working on.....Straighten it out, and, there's your length.....
When I make mine I put a flare on one end then bend the pipe leaving some excess, and only finally cut it (allowing for flare) once I've line it all end, then do the final flare. Don't forget to put the first nut on before you bend as they don't go around corners though.
While we're there, similar idea to BWA and the copper wire trick is to push a length of flexible bicycle brake cable up through the old pipe, add 5mm for the flares and that's it. So simple even I could do it!
