Block to gearbox dowel
gs.davies
Has thanked: 72 times
Been thanked: 69 times
Post by gs.davies »
Are there supposed to be one or two of these? And are they all the same size for all blocks?
Herbert
Re: Block to gearbox dowel
Post by Herbert »
There are two, on every mini engine/gearbox combination. One is hollow with a nut and bolt going thru it, on the timing chain side and it has a stepped washer on the block upper side. The other is solid. They both have the same dimensions
iain1967s
Post by iain1967s »
Yes, two. One solid 22H983 for the front end, one hollow 12H1824 for the extra clamp bolt at the rear (flywheel) end.
Herbert
Post by Herbert »
And if anyone wants the stepped washers , I have 5 of them. Its a non-serviceable part I think ! Pm me...
