Hinges
whistler
Has thanked: 18 times
Hinges
Post by whistler »
Are the Minispares external hinges sets suitable replacements for the original cast ones? Not sure whether to replace all the hinge pins/bushes or buy new alloy ones.
harrymini
Re: Hinges
Post by harrymini »
If you have a full set of hinges i would go with originals. Replacing the pins and bushes isnt a bad job, alot of the hinges i have to do have seized studs, so usually just build up a weld on it and then weld a 1/4 nut and remove.
Daz1968
Re: Hinges
Post by Daz1968 »
I would rather use originals, the mini spares ones look ok but shape is a little different, they also are m6 studs
kevs 1961 mk1
Re: Hinges
Post by kevs 1961 mk1 »
harrymini wrote: Wed Jun 02, 2021 8:19 pm If you have a full set of hinges i would go with originals. Replacing the pins and bushes isnt a bad job, alot of the hinges i have to do have seized studs, so usually just build up a weld on it and then weld a 1/4 nut and remove.
i used new pins and bushes on my old hinges and they still had play in them ,so i used new minispares hinges, problem solved
long time gone
