Which sump guard should i use?
Posted: Sat May 22, 2021 3:32 pm
by harrymini
My historic replica is nearing completion now, car is away at a specialist getting the engine tuned, suspension set up etc.
Wanting to put a sump guard on it and wondering what people like to use?
Re: Which sump guard should i use?
Posted: Sat May 22, 2021 6:14 pm
by Peter Laidler
Have you ever thought outside the box Harry? Do you actually NEED a sump guard for your replica? Are you going to use it in earnest or do you want it to look the part. I ask because my friend here likes the LOOK of the sump guard and a few extra lights on his look-a-like replica rally type mini but ain't never going to use it hammer and tongs. So he's made himself a truly (and I mean spectacular...) good looking lightweight, much thinner sheet metal replica that he's had welded up by a small engineering works on an industrial estate locally. Looks like the real McCoy but 1/3rd the weight - and price. Just thinkin'.......
Posted: Sat May 22, 2021 7:14 pm
by harrymini
Good point, maybe i should try without for a while, just dont fancy cracking the ally sump with the crap roads / obstacles in the roads where i live.
Posted: Sun May 23, 2021 1:40 pm
by AndyPen
harrymini wrote: ↑Sat May 22, 2021 7:14 pm
Remember the old iron Scottish ones? The car might not survive but the sumpguard coped admirably here in the welsh testing grounds
https://www.youtube.com/watch?v=0ZGjCkbWwmo
Posted: Mon May 24, 2021 3:05 pm
by MiNiKiN
I must admit I hit the "play button" above.But only once
The Innocenti sumpguard is quite sturdy - sadly the replica from MS is only half as good as the original and doesn't fit the original mounting points either.
