Am I right in thinking that the 'FRONT' marking should read the right way up when viewed from the front of the engine block as it's installed in the engine bay?
The pistons have a horizontal split beneath the lower ring on the opposite side to the FRONT lettering and nothing on the front - my presumption is this split should be on the manifold side of the engine?
The pistons are located on the rod with a circlip either side - in the event that these are back to front, is this something I can do myself? The machining was done many years ago now and I doubt I'll get much change from taking them back some seven years later
