Door latch thread - heritage doors
gs.davies
Has thanked: 72 times
Been thanked: 69 times
Post by gs.davies »
I’ve had to grind out a bit of metal to expose fully the thread for the door latch on my heritage doors. However, the screw does not want to engage at all.
Is the thread the same as the original or do I need a different screw?
Has thanked: 139 times
Been thanked: 119 times
Re: Door latch thread - heritage doors
Exactly which screw threads do you mean? Photo?
gs.davies
Post by gs.davies »
These two...
gs.davies
Post by gs.davies »
I’ve managed to get the captive nut exposed and it definitely isn’t the same thread :-/
Ah, yes..... They were all UNF surely? Maybe you could ID the thread by screwing a bit of hardwood into the hole. The thread will mark the wood and you'll be able to do a core dia and TPI check. A bit agricultural but it works. Or maybe the threads just need re-tapping. I wonder if they've gone to metric.
gs.davies
Post by gs.davies »
Well, I did try the screw and it chewed the end so I presume the thread is different and probably metric.
I’ll try ringing heritage tomorrow and see what they say.
Just wondered if anyone else had encountered this before.
Maybe someone with a new set of doors from Heritage could conform the thread. Then GS could tap out the threads to suit. Might save a bit of aggro
gs.davies
Post by gs.davies »
I spoke to heritage this morning - they confirmed that what SHOULD be in there is a 10/32 UNF captive nut. I'll try to obtain a tap and run that through, see if that helps. I'll also measure the screws that came out of the original doors and see if they are 10/32 UNF...
gs.davies
Post by gs.davies »
..and I also tried Peter's suggestion of running a piece of dowel through and see what happens.. Initial measurements seem to indicate that my doors have a number 8 captive nut.. I shall make enquiries with my mate who I had entirely forgotten owns a fastener business, so hopefully they can give me a few sample to try.
Until then :D , my doors are flapping open
Post by Old English White »
I purchased a new Heritage door when restoring one of my Minis. It was not a happy experience and the panel was all over the place :( Very poorly assembled and never fitted properly. I had exactly the same issues. Nothing lined up and I had to re-tap the threads - although that in itself is common on newly painted panels of course.
gs.davies
Post by gs.davies »
Old English White wrote: Mon Apr 26, 2021 11:36 am I purchased a new Heritage door when restoring one of my Minis. It was not a happy experience and the panel was all over the place :( Very poorly assembled and never fitted properly. I had exactly the same issues. Nothing lined up and I had to re-tap the threads - although that in itself is common on newly painted panels of course.
Yes, I guess that retapping to the correct size is the proper fix for this. Did you just go through the captive nut that was already there with a 10-32 tap?
In a word, yes......., but....... If the hole is full of paint then just go through and back out. But if it's got weld spatter in it, just go very carefully. In a bit and out... gently does it
Another example of Heritages superlative quality! How much are those doors? Over £500 a piece if I remember rightly!
Herbert
Post by Herbert »
I had a mate with the same problem, the thread was metric. Why? no idea. Bought some metric screws and they fitted fine, although the aperture wasnt in the right place. All the Heritage bodyshells are the same. Be careful of the door hinges, they are metric as well....
Clearing/tapping out the hole shouldn't be a problem. But it'll be a bit of a bugger if it's 5mm metric - or not positioned correctly.
gs.davies
Post by gs.davies »
mk1 wrote: Wed Apr 28, 2021 3:15 pm Another example of Heritages superlative quality! How much are those doors? Over £500 a piece if I remember rightly!
Yep. £500 a side and I had a pair.
Bit late to take them back now since I’ve had them six years 😂
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
Unbelievable that nowadays with modern technology they are just not capable to produce the same quality or better than back in the days...
Fanfaniracing wrote: Thu Apr 29, 2021 9:44 am Unbelievable that nowadays with modern technology they are just not capable to produce the same quality or better than back in the days...
I really don't think that is the case. The thing that makes stuff like this so difficult nowadays is small batch production. When they were making thousands of doors a week they HAD to be perfect every time. If they weren't, the line would grind to a halt every 5 minutes. Now these things are made in 10's if that. There isn't the chance to get a system in place to ensure REAL quality control.
Yes, I agree when you are paying £500 for a single door, you should be able to fit it without problems, but if the volume isn't there, the quality probably won't be either.
This is the exact problem that effects the vast majority of remade parts.
mini_surfari
Post by mini_surfari »
On a side note
I've heard a rumour from a well known heritage supplier, that there are a new batch of wings that are being tested at the moment....
Apparently when the press was moved, it was reassembled without a certain set of shims in it. They've now been added, and tested. Will see if I can find out more on the subject.
I bet they will still need a load of fettling to fit right.
