Wiring
Steve A
Wiring
Post by Steve A »
I have fitted a lucas boot mounted reverse light which has two wires coming from the back. The gearbox i have has the reverse light switch fitted to the front again with two terminals i think? How all this is linked up? What size cable do i need to use? As you can tell i haven't a clue about electrics :roll:
Thanks Steve.
Smiffy
Re: Wiring
Post by Smiffy »
Green wire from A4 fuse to the switch and green/brown from the switch to the light's red wire. The lights black wire goes to the body using a ring terminal on one of the boot hinge studs.
For the wire I used:
http://www.autosparks.co.uk/product_inf ... ts_id=1286
Steve A
Re: Wiring
Post by Steve A »
Thanks smiffy, just had a look at the link and they also do a cotton braided covered wire which looks nice, regards Steve
Steve A
Re: Wiring
Post by Steve A »
Just ordered some braided cable and connectors etc. Suprised how cheap they are. Thanks again
Smiffy
Re: Wiring
Post by Smiffy »
Yeah that surprised me as well, rich put me onto them.
The proper bullet tool, makes it so much easier than messing about with solder.
