Tachometer Question
ltgo168
Tachometer Question
Post by ltgo168 »
Hello,
I have a unbranded Tach that bounce and would like to install a new one for a while. The question is mine has red, green, black and white. But the one I want to install has a different colors as you can see in the picture. I try to drag and drop but can't. The tachometer is from Mini Spare and part #SIB140, how can I connect these wires or can't. Thank you
Re: Tachometer Question
You will be able to fit the SIB 140, but you may have to run some new wires. It is impossible to tell what the wires on your current tacho are doing or where they are connected.
There are full fitting instructions available here:
https://www.caigauge.com/product-instructions
What you must do is ascertain what your current wires are doing, once you know this you will be able to wire the new tacho.
Hope this helps.
ltgo168
Post by ltgo168 »
Thank you for yours reply, I'm go and place that order.
