Water Pump (Electric?)
Posted: Sat Jul 24, 2010 1:47 pm
by bluemin
I'm getting the squeaky squeaky so a new water pump looms.
Thinking of an electric one rather than the conventional. Anyone fitted one? Type? Good points. Bad points. Pitfalls. Easy to fit? What's needed to fit etc etc.
Cost might be a problem. KAD do a kit https://secure.surfinteractive.co.uk/cg ... MiniEngine but it costs £208.82 :o
On the other hand Merlin have pumps at £89.00 (Bosch) & Davies Craig at £134.99.
D.T. Have what they call a "booster pump" which might do at £93.99.
So advice please
Re: Water Pump (Electric?)
Posted: Sat Jul 24, 2010 9:33 pm
by littler
there ok for all out race cars,
but there not 100% reliable,
unless you actuly think its needed there is no point,
Posted: Mon Jul 26, 2010 9:34 am
by tomkidd
Apparentlt these guys sell to KAD...
http://www.corley-conversions.co.uk/
I'm thinking along these lines at the moment too, if you take away the water pump but still have the alternator is it really worth it? does the alternator not pull much power?
Posted: Mon Jul 26, 2010 4:10 pm
by bluemin
Yeh Ben Boult..........No comment.
I actually have one of those pumps which I was going to fit into an Imp based car but decided not to bother.
Really I'm basically looking at reliability. Is it more reliable than the standard jobbie? Certainly would help with the cooling once the engine is switched off. Not bothered about the extra 2BHP. ;)
Posted: Mon Jul 26, 2010 4:13 pm
by tomkidd
The corley one is the same as the KAD one... KAD have said they know of no problems associated with using one...?
Posted: Mon Jul 26, 2010 5:12 pm
by Smiffy
One problem I can see, is when/if it packs up. You won't find a replacement at the local motorfactors.
Posted: Mon Jul 26, 2010 5:14 pm
by bluemin
Yes but have any of the mob on here actually fitted one? Anyone know what's involved in the way of revised tubing, belts & etc.
Posted: Mon Jul 26, 2010 5:27 pm
by Smiffy
You'll need to fabricate a blanking plate with the bottom hose outlet on it, when I was considering this. I looked at Renault (sencic & 19) and vauxhall pumps. As these would/should be more readily available, if it packs up in some backwater.
Posted: Mon Jul 26, 2010 5:31 pm
by tomkidd
Posted: Mon Jul 26, 2010 6:07 pm
by Smiffy
That looks overly complicated, just make your own
Posted: Mon Jul 26, 2010 7:43 pm
by bluemin
Thanks both. Must admit that I'd go for the £35.00 jobbie as making it myself isn't a good idea. :o :shock:
Any other tips such as hosing to use?
Posted: Mon Jul 26, 2010 9:48 pm
by InimiaD
Are you using a side mounted rad as per normal or a front mounted rad.?
If you're using a standard rad set up there will not be much room to route the hoses. Most if not all of the Migs and Se7ens use an electric pump, but their rads are normally front mounted.
Next time I visit my mates place I'll try and take a pic of the set up on one of his cars if it helps.
Posted: Mon Jul 26, 2010 10:45 pm
by bluemin
Thanks. Rad is side mounted & it's a rally car.
Posted: Tue Jul 27, 2010 9:19 am
by tomkidd
Smiffy wrote:That looks overly complicated, just make your own
My time costs more than £35 an hour and all the cock ups I'd make along the way trying to make my own ;)
Posted: Sat Jul 31, 2010 9:36 pm
by InimiaD
Managed ro get a few pics of an electric pump setup.
As I thought, there is no room if using a normally mounted rad and if you do away with the standard pump what fan system will you be using.?
Anyways, my mate only uses Davies Craig pumps and they are very reliable, (until next time he goes racing and the pump goes pop. ;) )
Cooling system on his Se7en. The pump is connected inline to the bottom hose.
Hope this helps.
Dai.
Posted: Wed Aug 04, 2010 11:24 am
by bluemin
Thanks for that Dai. Looks complicated enough with a front rad never mind a side one. :shock: Might shelve the electric pump meantime & think on it for a future (Winter?) project.
Posted: Thu Aug 05, 2010 1:20 pm
by graham in aus
InimiaD wrote:Managed ro get a few pics of an electric pump setup.
Not a good advert for belt drive alternator!! :lol:
Belt flipped U/S dowm! :geek:
