Removal of Gearbox bearings
- gs.davies
- Has thanked: 72 times
- Been thanked: 69 times
What's the best and least destructive way of removing the first motion and double roller bearing?
I'd like to attempt transplanting a gearset from an 22G1832 into a 22G846 box, and if they're serviceable for now, the bearings too. I suspect the 1832 gearset is in good condition.
Re: Removal of Gearbox bearings
check out classic mini diy on youtube, rod change gearbox parts 1-3.
part 1 covers dismantling, theres a special tool from guessworks that helps drive out the double roller.
https://youtu.be/KEcx0y7vuGg
Caution
may contain 8 Ports, Xe's and VTec's, I don't do standard!
Caution
- Has thanked: 8 times
- Been thanked: 22 times
There is a Special Tool for this. I don't remember the Churchill number.
It's looking like a C.
May i can take a Picture for you tomorrow
- iain1967s
- Been thanked: 7 times
I used a sharkbite 3/4” plumbing clip release tool
Caution
Caution
- gs.davies
Good stuff. So that'd be the third motion shaft out, what about the first motion shaft? Think that has to come out first and the Haynes manual talks about using a brass drift. Is there a 'safer' way to pull it than that?
The C shaped tool can be made from a stack of big washers with a slot cut out - sometimes this can be easier as you can build up the stack gradually as the bearing starts to move.
The nice way to remove the first motion is to make a slide hammer attachment that screws onto the 1st motion shaft nose in place of the input gear nut.
The other way is to use use the mainshaft to drift it out. This also then opens up the gap for the tool of choice for the 3rd motion bearing.
However, cover the shafts with a rag as the synchro balls will make a bid for freedom.
Interestingly, Guessworks advises drifting the 3rd motion bearing out by its centre, not by its outer race. Apparently it does less damage to the bearing and if it does fall apart, then it was buggered anyway.
- gs.davies
Neat idea!
I presume this is because the syncro hubs get pushed past the limits of travel of the selector forks? I REALLY don't fancy trying to reassemble a syncro hub.. I'm capable of colourful language but I'm not sure I actually have the stamina for swearing that looks like it requires..GraemeC wrote: ↑Fri Mar 05, 2021 3:49 pm
However, cover the shafts with a rag as the synchro balls will make a bid for freedom. I REALLY don't fancy trying to reassemble a syncro hub.. I'm capable of colourful language but I'm not sure I actually have the stamina for swearing that looks like it requires..
How would that be acheived? Presume the mainshaft still gets nudged towards the flywheel side to open up a gap to get to the bearing and then go at it with a drift I suppose..
The synchro outer is held by the selector forks, however the inner moves with the mainshaft - eventually it moves far enough that the balls become exposed and the springs launch them out. You'll be lucky to avoid it to be honest but rebuilding the synchros isn't difficult, just a bit fiddly.gs.davies wrote: ↑Fri Mar 05, 2021 3:59 pmNeat idea!
I think the Guessworks tool will naturally push on the inner race of the 3rd motion as that race is slightly prouder if I remember rightly.
Some of the original factory tools were relieved in the middle so their outer edge would push on the outer race of the bearing.
- gs.davies
I'll just have to have a go at it. Fingers crossed the bearings don't collapse (or is more likely, I destroy them getting them out)
Mind you, given that the selector mechanism is jammed on this box (somehow the selector crank has ended up with its lever facing the flywheel side..
WHere abouts are you ? Ive got all the Churchill tools needed. I wont lend them out....R
- Has thanked: 186 times
- Been thanked: 65 times
There's some good and clever suggestions for the Mainshaft Bearing Removal Tool.
This is the one I made some 40 years ago, from another bearing;-
I did make a tool similar to the factory one a few years back, but I still prefer this one.
Oh, if if following some of those video guides, some talk about heating casings to remove some of the bearings. This is the factory's advice regarding that practice;-
- gs.davies
- Been thanked: 32 times
Before I bought the guessworks tool I used three primary gear " C" rings taped together .... ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Porsche 997 turbo S
I am from Essex
- Has thanked: 4 times
- Been thanked: 9 times
I used a brass drift and tapped it round, but maybe not the best way to do it for reusing the bearing.
Assembling a Synchro Hub is one of the easier tasks on rebuilding a gearbox.
With the right Tools of corse...
- JohnA
- Location: Up north where men are men and sheep are frightened
Why do these people make such videos when they have little knowledge or experience ?
Are they on some sort of ego trip ?
- gs.davies
on about Coles vids John?
He does stress he's an amateur and welcome to comments and corrections.!
Its called sharing the knowledge, if you think he doesn't know much then you'd be shocked how little newer younger owners know
Its err illuminating at times!!
Caution
Caution
