1071 compression ratio question
- Been thanked: 32 times
i have a slark race head with 15.8 cc . What would be the compression ratio be if used with flat top pistons .... Bore size is +40 . Thanks ken
1963 austin Cooper s mk1 1071
1966 Austin Cooper s mk1 1275
1968 Austin Cooper mk2 998
1962 Morris mini super 850
Porsche 997 turbo S
Ford transit van 280s.
I am from Essex
Porsche 997 turbo S
I am from Essex
- LarryLebel
Re: 1071 compression ratio question
I get a bit more than that.
The following calculation assumes 1071 crank, +40 thou overbore & 10 thou between piston & deck.
- Has thanked: 8 times
- Been thanked: 22 times
could not explain it better than mark!
The block is +20 at the moment and needing a rebore , hence why I’m asking the comp ratio at + 40 . So to add to the original post , what cc pistons should I use bearing in mind I will be using the 15.8 slark head and a swiftune SW10 camshaft , twin H4 carbs .... thanks for reply’s .... ken
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
6.5cc dish would give about 11:1
If it was mine, I'd be aiming for 10.5:1.
I'd machine a bit off the top of the pistons to give 15 thou clearance between the top of the piston & the deck.
Yes it’s for the road mark. Not to worried about a slightly lumpy tick over . I know that you’ve had a few 1071 so what make of Piston would be the best to use . . Thanks
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
Personally I stick with die cast omegas in most applications nowadays, but a slightly less expensive alternative is the MS / Swiftune C-STN103's
That’s great thanks. Omega pistons it will be . ... ken
Porsche 997 turbo S
I am from Essex
Porsche 997 turbo S
I am from Essex
