850 Compression Ratio
gs.davies
Has thanked: 72 times
Been thanked: 70 times
Post by gs.davies »
I’ve got a standard 850 head that needs a light skim to remove a bit of surface corrosion. Is there are benefit in getting a more drastic skim done to increase the CR over standard?
If so, how many thou?
Re: 850 Compression Ratio
If it is otherwise standard, there is no point in doing any more than a skim to get it flat.
Dearg1275
Post by Dearg1275 »
I disagree. Raising the compression ratio increases the combustion efficiency and produces more power. The down side is that you will have to use a higher octane fuel or retard the ignition (which defeats the object). If you can run a higher octane fuel then going to 9:1 can only be good news even on a standard 850. Every little bit helps on small bore engines.
bwaminispeed
Post by bwaminispeed »
You can go 50-60 thou on an 850 head, without problems, on regular fuel.......
