Mk1 brakes - has anyone fitted a servo?
Bitsilly
Post by Bitsilly »
Further to this thread from September:
http://mk1-forum.net/viewtopic.php?f=5& ... es#p255492
I am revisiting my brakes.
Mini Spares told me that a servo master cylinder won't fit under the mk1 bonnet hinge.
However as the car is going to be quite quick but also heavy, and driven by my wife, so I have decided to fit a servo.
Has anyone else done this on a mk1, and if so how? Does the servo have to be a remote one?
As usual, thanks!
Bitsilly
Re: Mk1 brakes - has anyone fitted a servo?
Post by Bitsilly »
However, I see the mini spares site sells a Cooper servo for a Mk1??
It is out of stock so MAYBE they were talking about another servo master?
Slowly losing my marbles here!
Has thanked: 187 times
Been thanked: 65 times
I'm not sure what Mini Spares were referring to there ??
You'd normally use the same Master Cylinder - if you have Discs up front, it's a good idea to use a Cooper S Master as it has a bigger Reservoir - together with a remote Servo. If you aren't looking for period parts, there's many firms who offer these types of Servos, be aware though there is many cheap servos on the market these days, which seem OK, but there's no kits available for them.
These guys seem to have a good name
https://www.powertrackbrakes.co.uk/brakes.html
or CBS have a couple
https://www.carbuilder.com/uk/compact-r ... r-assister
Just be careful of the Servo ratio, on a Mini, you don't need a lot, the Cooper S one is 1.9:.
If the ratio is too high, you'll loose too much feel and it could be tricky to drive.
GraemeC
Post by GraemeC »
I presume they mean you can’t fit a late model inline servo.
A remote one will fit fine and you can out it where you like (within reason), but most would use the proper Cooper S brackets on fix it into the inner wing
Bitsilly
Post by Bitsilly »
So would this fit with a Mk1 bonnet hinge?
https://www.minispares.com/product/Clas ... 0to%20shop
Or this?
https://www.ebay.co.uk/itm/Brake-Servo- ... 1438.l2649
I would just prefer to use standard Mini stuff rather than a remote one.
GraemeC
Post by GraemeC »
Yes, both will fit.
They are standard Mini stuff - remote servo was factory fit on cars with a servo up to about the 90’s when the in-line servo came in.
Bitsilly
Post by Bitsilly »
Most excellent!
olddave
Been thanked: 12 times
Post by olddave »
A couple of pm's sent :ugeek:
dodge44
Post by dodge44 »
This had been covered on here before quite recently with a few location options illustrated:
http://mk1-forum.net/viewtopic.php?p=232884#p232884
whistler
Has thanked: 18 times
Post by whistler »
There's 4 possible locations to fit a remote servo. I've used 2 of them and seen the other 2.
1. Inner wing where Cooper S one is fitted.
2. Under the wheel arch with a remote air filter poking through the inner wing into engine bay.
3. Under passenger dash, up against bulkhead.
4. Extra wide bulkhead box (as for weber carbs) and fitted there.
I've used 1 and 3.
If this is for your electrification you'll need an electric vacuum pump methinks.
Bitsilly
Post by Bitsilly »
Thanks all,
and yes I have already bought a vacuum pump.
InnoCooperExport
Has thanked: 4 times
Post by InnoCooperExport »
If you can't find the AP servo, you can also get the Alfa Romeo one for the 105 series Coupe as made by Bonaldi/Benditalia. They're not cheap, I think you'd be better off with a slightly later Lockheed unit such as: http://minispares.com/product/Classic/B ... 0to%20shop
998fan
Post by 998fan »
Bitsilly wrote: Fri Feb 05, 2021 11:43 am Thanks all,
Slightly off track, what sort of vacuum pump have you bought?
Bitsilly
Post by Bitsilly »
I went for a cheaper version of the rotary vane pump popular in the States at the mo.
There are much cheaper ones out there but as I have dynamatted the whole car I thought the quieter rotary vane one would be better.
