Fuel tank neck grommet
colonel mustard
Post by colonel mustard »
I bought a pair of rubber fuel tank neck grommets (bit of a mouthful) circa 6months ago. The car is still in restoration and has been in the garage and the grommets have started to ‘dry out’ and crack!
I know NOS is favourable but if this is not an option, where would new be best bought from apart from the obvious!
whistler
Has thanked: 18 times
Re: Fuel tank neck grommet
Post by whistler »
Try lubrication with glycerine.
If you can't get NOS then the only option really are good used ones Drew.
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Post by Fanfaniracing »
Where did you buy them?
I got the Minispares ones and they look not to bad. A bit more shiny than yours...
colonel mustard
Thanks all
Not sure if they are the cheap or expensive ones but they were from MInispares.
I have been coating them up with vasoline with not real results.
Will dig through the old box to see if I have any original ones that need cleaning up!
Hipwell
Post by Hipwell »
MS do an Epdm one now to.
I have it on good authority (a certain bearded guy ;) ) that the new MS ones are excellent.
MiNiKiN
Has thanked: 86 times
Been thanked: 31 times
Post by MiNiKiN »
If you find old non-NOS ones - put them in the washing machine at 40deg with some fabric conditioner. Worked perfectly on my old rubber items, it really softens them. Then put on some tyre foam and let it soak in.
:!: Disclaimer: Thou shalt not get caught by the regnancy :!:
colonel mustard
Well managed to find a couple of neck rubbers in the bottom of grease box! Not looking to bad, will try the washing method albeit when the wife is out for an hour!
Marcus, you mentioned tyre foam? Is the tyre dressing solution?
Also the profile is less bulky on the original ones (assume this pair are original?)
spraybeateer
Post by spraybeateer »
Here is the new Minispares one fitted, supplied courtesy of our good friend Rich ;)
fitted to replace previous mini spares one, it had nowt wrong with it! this just looks
nicer.
MiNiKiN
Post by MiNiKiN »
It is called "Reifenschaum" in German - available from Würth and the likes (Nigrin, Sonax, ..) - probably depends where in the world you live.
Here is a selection I get from the search engine:
https://www.ecosia.org/images?q=reifenschaum
colonel mustard
I think I have some in the garage!
Thanks spraybeater, maybe an alternative option of the washing machine Method does not work (Machine currently working it’s magic!)
colonel mustard
Here’s the results, both have come up cleaner and a tad softer, not much tho, after a night of soaking in tyre dressing foam stuff.
The drivers side is a little perished but will do till I can find a better one.
And the drivers side tank hole is to large for the grommet so trimmed one of the new ones down and used it as a second collar. Not great but works
colonel mustard
Thanks Mark
Will put a couple on the order at the end of the month.
