Van quarter panel bodge woes
mini_surfari
Post by mini_surfari »
Foolishly I thought the van bodywork was coming to an end...
However what I thought would be a gutter repair, and possibly a new skin has turned out to be more sinister.
The door fit on the drivers side has always been naff. And now I think I know why.
Hopefully the photos make sense. I am unsure how to remedy this repair, with out it becoming a 'modern' bodge. So as always, advice from you guys would be greatly received.
(I have tried making the photos smaller, if they are too large let me know and I shall adjust).
Here you can see the the passenger side drip rail... as the factory intended, spot welded underneath the gutter (which I assume is apart of the quarter/ side panel). As per the factory.
Now this is the drivers side, where the side panel goes over the top of the drip rail...
But only up until this point, where it looks like the door frame has been cut and welded to the new side. However where they have left the drip rail the door frame is too low at the back.
SO, from that seam weld back, the quarter panel/ side panel seams to have had the roof gutter removed and putted up against the old gutter) causing a sandwich of rust. Meaning its all pretty knackered.
How is this best to fix this mess? Ideally I would like to find a NOS side panel (seen them in the past before I owned a van) but that is like looking for hens teeth in a pile of rocking horse poo.
Thanks in advance,
Oli
coop12g295
Re: Van quarter panel bodge woes
Post by coop12g295 »
Hens teeth are more common, I sold my NOS full side for £800 last year
Gsu754
Post by Gsu754 »
Hopefully there is somebody out there with a quarter panel for sale or advise on how to rectify the repair. It would be a shame to see another van head for the scrap yard especially after all the hard work all ready done on it and being so close to painting.
bwaminispeed
Post by bwaminispeed »
Seriously tough repair.......
If it's just that area you are fixing, any MKI-II saloon will do, either repair panels, or, even better, cut out of an otherwise rotted salloon......That area is usually OK, even in a well rusted out car.....
minibitz
Been thanked: 13 times
Post by minibitz »
I've got a NOS R/H full rear quarter......but I'm in New Zealand.
mini_surfari
bwaminispeed wrote: Tue Dec 22, 2020 11:34 pm Seriously tough repair.......
Typically its not isolated to just the door frame, its swelled and rotten from the drip rail all the way to the brazing on the rear by the back door.
