Pistons identity
Tedwong
Pistons identity
Post by Tedwong »
Hi can anyone identify this piston and most importantly can I buy rings for them? It was removed from my Mk3 Cooper S engine! Not original pistons I guess ;)
Thank you very much!
Ted
Has thanked: 187 times
Been thanked: 65 times
Re: Pistons identity
Check the Ring widths, I'm sure those are 1/16" and 5/32" on the Oil Control.
If they are, then Grants P1280 are the ones.
Tedwong
Post by Tedwong »
Looks like they are roughly that sizes! Marina pistons?
Ted
GraemeC
Post by GraemeC »
I think these pistons were used in some Metros (MGs maybe?) but whether they were used in early engines I don't know.
LuisM
Post by LuisM »
Code: Select all
as Graeme pointed, i have an early 1275 S Metro engine ( non MG with small valve "flat thermostat" head from factory ) and it uses these pistons, i believe they are 9.75:1 compression .
GraemeC
Post by GraemeC »
Doing a bit of Googling, it looks like the same base casting was used for different applications with different dished and heights.
Looks like they were also used in some Metro turbo engines with a larger dish.
251 ENG
Post by 251 ENG »
If they are AE / Hepolite / Leyland / Rover pistons they will have a 5 diget part nimber stamped on top of pistons or cast inside skirt
timmy201
Been thanked: 40 times
Post by timmy201 »
251 ENG wrote: Wed Dec 02, 2020 1:14 pm If they are AE / Hepolite / Leyland / Rover pistons they will have a 5 diget part nimber stamped on top of pistons or cast inside skirt
It’s stamped in the skirt, just a little hard to read the numbers:
Hepolite
20852A or 20352A
Tedwong
Post by Tedwong »
Hi Guys, thanks for the reply!
The inner skirt was stamped Hepolite 20832A, no standard or overbore figure.
After googling, only small amount of information saying MG Metro non-turbo applications.
Btw, what pistons were used on standard MK3 Cooper S engine?
LuisM wrote: Wed Dec 02, 2020 11:39 am
Code: Select all
What is 1275 S Metro engine?
LuisM
Post by LuisM »
early metros had a less powerful A+ 1275 version ( here branded S / HLS ) , it had small valves "flat thermostat" head , tamer camshaft than the MG Metro, single piece cast inlet/exhaust manifold like the 1.0 metro, HIF44 , points distributor , and mine had verto flywheel and intertia starter from factory. It used these same pistons you've listed here.
Luis
Exminiman
Has thanked: 54 times
Been thanked: 52 times
Post by Exminiman »
timmy201 wrote: Thu Dec 03, 2020 1:31 am
Hepolite
20852A or 20352A
20832A ?
MiNiKiN
Has thanked: 91 times
Been thanked: 31 times
Post by MiNiKiN »
Just checked my Metro 1275 pistons and they have following cast numbers: Hepolite 20832A / 413P G4
timmy201
Post by timmy201 »
Exminiman wrote: Thu Dec 03, 2020 12:46 pm
Hepolite
20852A or 20352A
20832A ?
Yes, I should have written 20832A.
Tedwong
Post by Tedwong »
So, Metro pistons confirmed! Thanks!
MiNiKiN wrote: Thu Dec 03, 2020 2:30 pm Just checked my Metro 1275 pistons and they have following cast numbers: Hepolite 20832A / 413P G4
