Hello Guys
I have some troubles with my 160 kph speedo
it indicates well the speed but the KM counter doesn't work anymore stuck at 31900 km
Does anyone ever experienced that?
The cable is brand new but may be faulty? or it's a problem with the internal components?
Cooper mk1 speedo repair experts!
- Has thanked: 4 times
- Been thanked: 9 times
Re: Cooper mk1 speedo repair experts!
If it indicates speed the cable cannot be at fault, the fault must be internal. We had a Smiths MGA speedo rebuilt to like new by Speedograph ltd in the UK. They did a stunning job and now it reads accurate (had to have it recalibrated because we changed the FD in the diff to lower the revs at motorway speeds).
Almost certainly it will be wear in the little arm that pushes the drum around.
Not difficult to correct once apart. I've never bought a new arm, just been lucky and took one from another speedo.
- timmy201
- Been thanked: 40 times
Mine had a dodgy pin on the “tenths” wheel and wouldn’t push the next wheel around on time. The repair shop replaced the wheel and now it’s all good
I ask to a friend that rebuild his speedo
He said the speedo is maybe stuck? I will disassemble it and try to find the faulty spare,
is there any web shop with smiths speedo for sale?
- Ronnie
- Has thanked: 12 times
- Been thanked: 31 times
Read all about it here > http://obswww.unige.ch/~wildif/cars/doc ... repair.pdf
