Gearbox refurbishment advice
Gary Schulz
Has thanked: 16 times
Post by Gary Schulz »
Finally got the 333 gearbox apart and got the important parts disassembled. Things don't look promising at all...
I am pretty used to seeing things like layshafts and bearings needing replacement but it looks like the laygear (22G1100) is complete junk based on the inside bearing surface on the first gear end-
I would also say that the third motion shaft input side is junk as well-
Ouch, I just got a good look at 2nd gear and there is major damage to the drive dogs so 2nd gear is toast as well !
So am I just screwed here? Looks like I can find an aftermarket laygear but they are very expensive and I am not sure of the quality. What about third motion shafts and things like 2nd gear?
whistler
Has thanked: 18 times
Re: Gearbox refurbishment advice
Post by whistler »
Talk to John Guess at Guess-works. He has the technology and equipment to maybe sort that.
Hipwell
Post by Hipwell »
Sadly that does look all past it’s best looking at the photos.
Yep, sadly they look unserviceable.
Beware of some repro stuff, as its not always that good. Simon Naylor, 251ENG on here is the best guy to talk to.
Gary Schulz
Thanks for the tips guys. I sent an email to John Guess and I will try to PM Simon.
cmiller
Post by cmiller »
As in the e-mail I sent you just now, don't fret as help is on the way. we should be able to find usable stuff for you. Never seen that kind of damage before. That second gear is priceless and I would put it in our clubs "box of shame". The fun of restoring old Mini components can be very challenging.
Chris Miller
Craig
Post by Craig »
I have a couple of new and good used 22g1100 laygears if you don't have any luck else where .
I'm in western Canada.
Craig
MiNiKiN
Has thanked: 91 times
Been thanked: 31 times
Post by MiNiKiN »
For the bearing seats and shafts you could consider metal spraying and re-grinding. But that ain't help with the gear cogs I suppose.
This is my trusted service provider for metal spraying, there's surely one close to you too.
https://bvt-koller.at/en/services/coating
