Heater Hose Clips
rogerotto66s
Heater Hose Clips
Post by rogerotto66s »
1966 S, July build date, Personal Export to USA
While reassembling I found these 4 spring clips which I believe are for the two heater hoses.
However, AKD 3503 indicates these clips are used.
The clips are #52
What was the cutover date between these two types of clips?
How would I research? I have searched the forum multiple times.
Seems AKD3503 is for earlier minis. What manual would better apply to my ‘66 S?
Roger Williams
jerry
Re: Heater Hose Clips
Post by jerry »
The clips in the photo looks like the rocker cover to air cleaner rubber pipe clips
Hipwell
Post by Hipwell »
The x4 wire clips are correct for use on the heater hoses 66.
rogerotto66s
Hipwell wrote: Sun Nov 15, 2020 2:21 pm The x4 wire clips are correct for use on the heater hoses 66.
Is there a documented reference?
Roger Williams
