boot board brackets
Dean
boot board brackets
Post by Dean »
i want to fit boot board in my boot, but with a wheel with a 165 tyre,
i have just tried in my other car which has a boot board, and as i though its the tyre is too high
is there rear brackets out there maybe from mini machine that are designed for a 165 tyre, or has anyone else other there have a 165 tyre as a spare with a boot board, of so how did you do it
cheers
Austin Cooper
Re: boot board brackets
Post by Austin Cooper »
You can get raised height brackets from M Machine which are designed to clear a 165 tyre. I have just fitted some to one of my cars, as it didn't have the bulkhead brackets fitted I just fitted them so the board was level. If your car already has them I would expect the board to sit on top of the wheel rather than in the bulkhead brackets though. I did notice that fitted the way I have done it, it is very difficult to fit a standard boot board as the gap is narrower being higher up the boot.
Dean
Post by Dean »
Ok cheers. Glad to hear that can be done and mini machine do them as I need to do a order for panels got my elf so I also some higher boot board brackets for the mk1.
