Droopy door handles
Posted: Wed Oct 14, 2020 10:59 am
by Nick W
Well I've read about shimming these , and twisting them .
But to be honest the best repair is replace the mechanism, as this is the part that wears and they can still be bought nos for around £20...for now.
Here are some before and after fitting videos
https://youtu.be/8aEErOo0NHo
https://youtu.be/lckgeDf_-tk
Re: Droopy door handles
Posted: Wed Oct 14, 2020 11:57 am
by Tex1965
Very nice, thank you for sharing.
Is ebay the only channel to get them, or a is there company selling them ?
Posted: Wed Oct 14, 2020 12:12 pm
by Nick W
I don't know if any are being made but have seen quite a few for this money in UK
https://www.ebay.co.uk/itm/274533344379
I think they could be refurbished putting new parts in them, using original casings..which there are loads of
Posted: Wed Oct 14, 2020 4:57 pm
by cheesebadger
The other option, off the top of my head without looking inside one of the casing, would be a suitable torsion spring to support the weight of the handle. Would probably help with rattle whilst driving as well...
I'll add it my ever growing list of things to look at...
Posted: Wed Oct 14, 2020 11:09 pm
by 1071 S
cheesebadger wrote: ↑Wed Oct 14, 2020 4:57 pm
Mini Sport in Adelaide Oz sell these ..they call them "snail springs"..
They've done the job on my cars for years..
Cheers, Ian
Posted: Thu Oct 15, 2020 9:09 am
by cheesebadger
1071 S wrote: ↑Wed Oct 14, 2020 11:09 pm
Cheers, Ian
Good to know. Thanks.
I am always late to the party!
Posted: Thu Oct 15, 2020 10:11 am
by mab01uk
July’s MCR CooperWorld magazine Technical Topics series by Richard Pengelly, also explains a method on how to fix your droopy Mk1/2 door handles. I will try to find my copy, scan and post it here later.
Posted: Fri Oct 23, 2020 4:06 pm
by mab01uk
Posted: Fri Oct 23, 2020 4:17 pm
by Herbert
just looked at the Minisport Adelaide web site, cant find any such "spring". Does anyone have more details on it ?
Posted: Fri Oct 23, 2020 6:48 pm
by colonel mustard
I just cut up some old ball joint shims and wedged then into the lock when sliding the handle in. Once tightened with a the self tapping screw seem to tighten the handle in full. Was not keen on twisting the door handle
Posted: Sat Oct 24, 2020 1:55 am
by 1071 S
Make sure you’re on “ Minisport.com.au” and search for HYA3512. ($A14.95)
Cheers, Ian
Posted: Sat Oct 24, 2020 7:55 am
by Nick W
Also worth noting that after fitting the new latch, the door shut at the rear pulled in fractionally, so as the latch wears, it causes the door to stick out more than when new.
Posted: Sat Oct 24, 2020 8:46 am
by Aussie Bill B
Rolandino wrote: ↑Fri Oct 23, 2020 4:17 pm
https://minisport.com.au/morris-mini-do ... ail-spring
Doubt these will fit UK style handles.
Posted: Sat Oct 24, 2020 10:06 am
by Polarsilver
To be "original" just describe your Droop as Pat & Tina
Posted: Sun Oct 25, 2020 12:13 am
by 1071 S
Works on both my UK S and Traveller...
Cheers, Ian
Posted: Sun Oct 25, 2020 12:25 am
by Aussie Bill B
1071 S wrote: ↑Sun Oct 25, 2020 12:13 am
Cheers, Ian
Thanks Ian. One less thing to doubt about!
Posted: Sun Oct 25, 2020 11:12 pm
by Herbert
Thanks for info. Just ordered a pair. will keep you posted when I fit them. R
Posted: Tue Oct 27, 2020 4:33 am
by Tim
Part number HYA3512, they were used in Australian wind-up window doors. In my youth I made them from piano wire.
Posted: Tue Oct 27, 2020 4:34 am
by 1071 S
Rolandino wrote: ↑Sun Oct 25, 2020 11:12 pm
Just a hint... they are snail springs and I found that you need to wind them up a bit to provide enough preload to hold the handles up.... Not too far or they'll bind when you push the handle down...
Cheers, Ian
