Lower Dash Rail
YORKY
Lower Dash Rail
Post by YORKY »
Stripping car for restoration. What is the best method for removing the lower dash rail chrome strip and padding. ( mk3s )
Cheers Jim
jay weinstein
Re: Lower Dash Rail
Post by jay weinstein »
Use a short block of wood and a small hammer on the chrome strip...the padded part..pull and pray!
EMOKID
Re: Lower Dash Rail
Post by EMOKID »
Use of hairdryer on bottom rail covering to soften the adhesive and peel back very slowly a little at a time to prevent stretching if you are trying to save it.
Good luck!
Has thanked: 18 times
Been thanked: 51 times
Re: Lower Dash Rail
On the Ford I used glue remover and it worked a treat.
IAIN
Re: Lower Dash Rail
Post by IAIN »
As above. Carb cleaner will soften the glue. Try not to spray the plastic too much. It also works on the top rail covering.
