Just getting to the point of drilling holes into new metal panels throughout for the myriad of posi drive self tapping screws prior to the body going in to paint. The thought of drilling and screwing metal to metal seems like a recipe for future rust and wonder if others have come to a decision whether to stay original or install these plastic grommets?
I can't say the plastic grommets are always the answer as rust around the square plastic blocks occurred on my 15 year old BMW which uses the above blocks, I guess the paint is so thin on the edge of a hole the plastic takes it off any way when just pushing them in!
Also the square blocks are a pain to file into shape in the first place and to keep them close to spec, so the blocks are either not too loose or too tight!
Has someone found a neater idea? and are there round plastic grommets so drilling could be fast and accurate - even though future removal would have them spinning
The other problem of course is that by using a plastic grommet the item will be sitting pround by 1 or 2mm which is going to look naff and possibly cause the item to work loose if it has no mating surface to add to stability?
