Dismantling a speedo
rolesyboy
Has thanked: 6 times
Post by rolesyboy »
Hi. Does anybody have any tips or advice on how to dismantle a Smiths speedo and also how I can test it works off the car please? Thanks. Mark
guru_1071
Re: Dismantling a speedo
Post by guru_1071 »
mark
my only top tip would be to use a plastic fork to get the needle off with minimum damage.
you can test speedo by using a very slow electric drill and an old cable
rolesyboy
Post by rolesyboy »
OK. Thanks Rich. Next question: what causes the needle to fluctuate? Can I repair? Anyone got any instructions on dismantling/ rebuilding & 70's style "clocking" etc. Yes don't worry, this isn't Arthur Daly here. Just want to zero the speedo. I am sure my car has done well in excess of 300000 miles but don't think after 50 years it is really relevant what miles it has covered. Cheers.
guru_1071
Post by guru_1071 »
it can be many things, the speedo its self, binding cable, tight speedo drive or even a worn main bearing causing the gear kit to 'pulse' the cable.
mini129
Post by mini129 »
the inner speedo cable and the eccentric gears in the speedo are the main causes of fluctuation in a mini speedo
mini129
Post by mini129 »
by the way do not use a plastic fork to pop the pointer!
Grab the speed cup and turn the pointer anticlockwise
