MK1 Body Numbers
agricola
MK1 Body Numbers
Post by agricola »
I am trying to protect my body number from blasting. Trouble is I cant find it! Its a May 64 shell so where should it be? picture might help.
Hipwell
Re: MK1 Body Numbers
Post by Hipwell »
The body number is as circled here below.
agricola
Post by agricola »
That is spotted welded like a FE number I thought they were stamped/punched? I will have to go to the blaster but the front end is original with FE number on inner wing above radiator and cant remember seeing a tag like this could it be anywhere else?
Hipwell
Post by Hipwell »
Yes generally, except some export cars as below.
agricola
Post by agricola »
That very helpful those numbers show letters and numbers the Heritage certificate says only numbers.
Were letters added to export cars only?
Gareth Brandt
Post by Gareth Brandt »
Hipwell wrote: Tue Aug 18, 2020 12:47 pm The body number is as circled here below.
what cooper s ?
agricola
Post by agricola »
yes a 1275 built May 4th 1964. mind you had a few owners before me but cant find an evidence of replacement panels and Fe number perfect?
Has thanked: 18 times
Been thanked: 51 times
Was it only 850 Morris (Cowley) cars that had stamping on the driver's side crossmember reinforcement?
agricola
Post by agricola »
This is an Austin 1275 s
Yes but a good way to check the shell is to see if there is a stamping there - often goes unnoticed:-)
agricola
Post by agricola »
The floor is actually the worst part of what is a remarkably sound shell so I will look in the morning. Regrettably as its for rallying I have decided to replace the whole floor.
