Re: Pedal boxes
Posted: Wed Aug 05, 2020 8:44 pm
RHD types are different to LHD sorry to say, but I would think a RHD one easy to find.
Re: Pedal boxes
Posted: Wed Aug 05, 2020 10:27 pm
by Ronnie
Wrong section :oops: :oops: :oops:
Re: Pedal boxes
Posted: Wed Aug 05, 2020 11:09 pm
by Aginley
Don’t think mine was different? It certainly fitted anyway.
Re: Pedal boxes
Posted: Thu Aug 06, 2020 1:49 am
by minibitz
I've done a R/H/D to L/H/D for a guy taking his mini back to Qatar of all places. The R/H/D pedal box swapped over and worked fine on the left so can't see why it would't work going the other way.
The throttle pedal is a different story though, had to put a set into it to get clearance from the trans tunnel.
Re: Pedal boxes
Posted: Thu Aug 06, 2020 10:14 am
The later boxes, you can bend the arms on, but the early types that the column bolted up to, are off set towards the door depending on which side of the car they were intended for.
Re: Pedal boxes
Posted: Thu Aug 06, 2020 12:18 pm
by Maddog
I was aware that the throttle pedals varied on Mk1s between LHD and RHD, but I thought the pedal box assemblies were the same and interchangeable (ie clutch pedal, brake pedal and mounting box). I have both a RHD and LHD Mk1... Can anyone post photos of the differences?!
Re: Pedal boxes
Posted: Thu Aug 06, 2020 12:44 pm
by docka
Are there also differences in LHD/RHD throttle pedals?
Re: Pedal boxes
Posted: Thu Aug 06, 2020 7:13 pm
by docka
Minisprinter wrote: Thu Aug 06, 2020 6:27 pm
docka wrote: Thu Aug 06, 2020 12:44 pm Are there also differences in LHD/RHD throttle pedals?
This I know, yes there is, the bend is different
MS
Thanks. I may have a lefty to sell then
