Advice on Push button Starter Solenoids
- JeremyD
As we are all aware the nice shiney Lucas solenoids in their nice green boxes are rubbish and only last between 2 and 12 months, then fail for no reason, usually after a long drive and the car left in the garage until the next drive when it won't start. Does anyone know of a different manufacturer of the same type, or does anyone know where I can find a genuine, made in England Lucas.
- Has thanked: 8 times
- Been thanked: 22 times
Re: Advice on Push button Starter Solenoids
On a old scrapyard.
I got mine exactly 10 years ago as a used 1964 Part from MC Donald Mini's in edinburgh and it still works like it's new.
I would never ever buy a expensive new one...
Agree with above - original ones are far far superior.
I had a repro one come apart on a run back from a trip to Kent. Had to stop (before I realised what had happened) and had to get a guy in the lay-by to bump start me to get going again and prayed it didnt stop at a junction or anything
NOS ones come up every now and then but a good used one is fine.
- Has thanked: 18 times
- Been thanked: 51 times
My ‘new’ one failed after about 6 starts. One of many new things I’ve wasted money on of late
- Bitsilly
AFAIK they are the same as on a mk2 Jag.
If so I may have one lying around, or should be able to get one from the garage I sometimes work for.
If it is the same.. what is the code?
They may be old Lucas.
Let me know.
Let me know.
Durite make one that so far has been reliable for me.
I’ve always found their stuff to be good quality
https://www.durite.co.uk/itm/Starters/S ... 24V/033504
- Has thanked: 38 times
- Been thanked: 52 times
I will vote for the Durite Solenoid .. no issues with my two ..other than after a few years the rubber button will tend to falloff
Lakeland997 wrote: ↑Wed Aug 05, 2020 8:44 pm Durite make one that so far has been reliable for me.
Handy to know
- JeremyD
That link goes to a 24v solenoid. Can that be used on a 12v mini?Lakeland997 wrote: ↑Wed Aug 05, 2020 8:44 pm Durite make one that so far has been reliable for me.
- Ronnie
- Has thanked: 12 times
- Been thanked: 31 times
NOJeremyD wrote: ↑Fri Aug 07, 2020 9:22 amThat link goes to a 24v solenoid. Can that be used on a 12v mini?Lakeland997 wrote: ↑Wed Aug 05, 2020 8:44 pm Durite make one that so far has been reliable for me.
- Ronnie
But you could use one like this > https://www.gsparkplug.com/durite-solen ... 35-05.htmlRonnie wrote: ↑Fri Aug 07, 2020 9:45 amNOJeremyD wrote: ↑Fri Aug 07, 2020 9:22 amThat link goes to a 24v solenoid. Can that be used on a 12v mini?Lakeland997 wrote: ↑Wed Aug 05, 2020 8:44 pm Durite make one that so far has been reliable for me.
https://www.durite.co.uk/itm/Starters/S ... 24V/033504![]()
Durite do supply the 12v version... i have two on my cars.
