CLUTCH BALANCE.
GarysMK1
CLUTCH BALANCE.
Post by GarysMK1 »
Just a quick question gents... Does anyone on here know where i can get a full clutch assembly balanced, ie clutch plate, pressure plate and diaphragm.
in the Co. Durham area ?
Catmint
Been thanked: 15 times
Re: CLUTCH BALANCE.
Post by Catmint »
If you want to come south a bit to Northallerton, AMAC engineering has balancing kit
LarryLebel
Re: CLUTCH BALANCE.
Post by LarryLebel »
The clutch is quite light, I've never heard of including it in balancing.
scoop
Re: CLUTCH BALANCE.
Post by scoop »
LarryLebel wrote: Wed Jul 29, 2020 5:40 am The clutch is quite light, I've never heard of including it in balancing.
It's part of the rotating assembly, it absolutely should be balanced.
Louis
Re: CLUTCH BALANCE.
Post by Louis »
From researching clutches, it seems towards the end of production the whole flywheel/clutch unit was balanced before being fitted which is why Rover then sold them as complete units. Minispares even recommend balancing with new clutch kits but this may just apply to verto setups.
GraemeC
Re: CLUTCH BALANCE.
Post by GraemeC »
scoop wrote: Wed Jul 29, 2020 12:40 pm
The clutch driven plate can only be balanced with regard to itself though - and indeed could f*ck up the balancing of the flywheel, backplate and pressure plate if done as part of the assembly.
Given it is something that wears and is consumable, balancing it seems pointless.
And how do you actually alter the balance? The only place you could sensibly make adjustment is right at the hub which will have small effects (or you'll need BIG holes/welds)
smithyrc30
Re: CLUTCH BALANCE.
Post by smithyrc30 »
GraemeC wrote: Wed Jul 29, 2020 1:12 pm
It also 'stops' in a different place every time you use it relative to the clutch pressure plate and flywheel, so 99.9% of the time it will never be 'right' if balanced as part of the assembly.
Normally pressure plates are balanced by the manufacturer so will not require any further treatment. You can easily ascertain if they have because the splined hub will have a milled flat on it (Unipart, BMC and Borg & Beck plates were like this)
