Radiator shroud and engine mounts for my Historic rep
harrymini
Post by harrymini »
Hi guys, as some of you may have seen in the projects thread i am putting an a+ 1310 engine in my mk1 historic rep, got the subframe ready, picking the engine up over the weekend. I am starting to think about what bits i need to get the engine sat in the subframe.
For the actual engine mount i will be using these:
https://www.minispares.com/product/Clas ... o%20search
Then will a bracket like this work for the radiator bracket?
https://www.ebay.co.uk/itm/classic-mini ... %7Ciid%3A1
Then i am using a fletcher or minispares alloy rad, will a fan shroud like this work? or do i need something from a MK1? Bit unsure as i havent done anything like this before.
Any advice much appreciated.
Fanfaniracing
Has thanked: 8 times
Been thanked: 22 times
Re: Radiator shroud and engine mounts for my Historic rep
Post by Fanfaniracing »
Hi Harry.
Why don't you use a two piece Mk1 radiator shroud?
I have a Minispares Rad wich fitted perfect in the two piece shroud on my 8 port engine. And the cooling works perfect!
finchy533
Post by finchy533 »
The engine mounts you've linked are the cheaper versions - for the sake of a few quid, go for the 21A1902 (not 21A1902MS) ones.
http://www.minispares.com/product/Class ... A1902.aspx
harrymini
Post by harrymini »
Cool, thanks guys, will go for the better ms ones and see if i can find a 2 piece shroud.
M-Machine do the 2 piece shroud.
Has thanked: 18 times
Been thanked: 51 times
On my old racer the lower shroud was modified to get better access to the rad pipe. Am sure there is a good pic of a neat one on here somewhere. Mine was butchered in a hurry :-)
Also slotted the upper shround at an angle - so that the nuts were put in first the the shroud dropped over... the angled slot meant it got tighter as it slid on. A real game changer when servicing the car :-)
harrymini
Post by harrymini »
2 peice shroud from m-machine nearly £70 :shock: Will have to have a hunt round the stores just to make sure i dont have one :lol:
what models of the mk1 did that come on, just 's' or cooper and standard too?
docka
Post by docka »
harrymini wrote: Mon Jul 13, 2020 5:22 pm 2 peice shroud from m-machine nearly £70 :shock: Will have to have a hunt round the stores just to make sure i dont have one :lol:
If fitting a 1275 engine you’ll need the Cooper and S two piece shroud and lower bracket; they’re different to standard small bore ones to allow space for the crank damper.
Ask me how I know ...
M-Machine part number is 51.22.02.05
harrymini
Post by harrymini »
Thanks for the advice everyone, had a dig around and found a 2 piece rad shroud amongst other things :lol:
DUF2 ‘65 Elf
Post by DUF2 ‘65 Elf »
Harrymini if you are fitting a 1275 engine be aware you may need to make clearance to fit the fan belt over the bottom pulley.
The harmonic damper makes things a tad tight.
I had to modify mine to allow the fan belt to go over the pulley!
I hope that those 2 subframe spacers weren't out of the car you are currently re-assembling. They should go between the front subframe towers & the body crossmember.
harrymini
Post by harrymini »
Mk1: i use the same set on each car i do as well as the same straight subframe :lol:
Would be in a bad place if i had forgot to put them in wouldnt i :lol:
Fab60
Post by Fab60 »
The two piece radiator shroud is bolted into place or were they welded in place......
Two piece shrouds are held in place by 6 set screws, or occasionally self tappers.
