Floor dip switch
Posted: Fri Jul 10, 2020 5:36 pm
by colonel mustard
Hi
The original dip switch Has no identification On which terminal is which. Can anyone advise?
Re: Floor dip switch
Posted: Fri Jul 10, 2020 6:24 pm
by hanlminiman
Blue is the power supply. The other 2 are low (blue/red) and main beam (blue/white). I am also working on this and have been checking switches as Mini and mk1/2 Jaguar Lucas switches are different. :D
If you check with a multimeter all should be revealed. Don't forget the rubber mount to the bulkhead under the switch.
Cliff
Posted: Fri Jul 10, 2020 7:11 pm
by colonel mustard
Thanks Cliff, as always
Will do some testing, made a rubber gasket for it to sit on, look ok?
Posted: Fri Jul 10, 2020 8:45 pm
by woodypup59
Provided you identify the common terminal for the feed wire from the light switch, the other two don't matter.
The dip switch simply toggles between them.
