Anybody have the part numbers for a 3.1/3.2 final drive gear set
for a A drive B box (22A1288) has S 3 syncro gears
Final drive gear set part numbers?
- 65MK1S
- Has thanked: 188 times
- Been thanked: 66 times
Re: Final drive gear set part numbers?
3.1 set is made up of a DAM2806, 61 tooth Crown Wheel with a DAM2808, 19 tooth Pinion
3.2 set is made up of a DAM6327, 59 tooth Crown Wheel and uses the same Pinion as above.
These were only made by the factory in A+ types gears, but will fit the earlier boxes OK, though, you may need to grind some material from the Mainshaft Bearing C Retainer to fit the Pinion in.
@spider
you twisted the numbers so little correction
3,2 is made by 61/19 tooth (DAM2806/DAM2808)
and
3,1 is made by 59/19 tooth (DAM6327/DAM2808)
and
