early seatbelt mount oriantation
Posted: Sat Jun 13, 2020 6:21 pm
by Mark1Peachey
I'm after some advise regards fitting the seatbelt mount back into the exhaust tunnel of my '61. I have the eyelet, a threaded plate and then the nut. I seem to remember the eyelet being inside (obviously :lol: ) then the plate under the floor and then the nut done up tight to the plate but its been about 8 years since I took the car apart!! Is this the correct way to have this as it seems slightly odd to have a nut tightened up to a threaded plate other than to lock the plate off.
Many thanks, Mark.
Re: early seatbelt mount oriantation
Posted: Sat Jun 13, 2020 6:40 pm
by trevorhp
Stops the plate jiggling round and damaging the paint surface ;)
Its also an FIA requirement for racecar belts :)
Posted: Sat Jun 13, 2020 7:55 pm
by Mark1Peachey
Cheers Trevor always good to confirm my thoughts.
Posted: Sat Jun 13, 2020 8:06 pm
by Andrew1967
Mark,
On my 60 there is a 1/4 UNF bolt that goes into the smaller hole to stop the plate twisting.
You probably know that, thought I'd point it out just in case ;)
Posted: Sat Jun 13, 2020 9:11 pm
by Mark1Peachey
Hello Andrew,
Strangely that smaller hole isn't treaded and there wasn't a bolt in it when I stripped the car but it does make sense to have one there, thanks for letting me know.
Mark
Posted: Sat Jun 13, 2020 9:17 pm
by Andrew1967
No worries Mark
Nut and bolt required as they aren’t threaded as you rightly say :)
