early seatbelt mount oriantation
Mark1Peachey
Post by Mark1Peachey »
I'm after some advise regards fitting the seatbelt mount back into the exhaust tunnel of my '61. I have the eyelet, a threaded plate and then the nut. I seem to remember the eyelet being inside (obviously :lol: ) then the plate under the floor and then the nut done up tight to the plate but its been about 8 years since I took the car apart!! Is this the correct way to have this as it seems slightly odd to have a nut tightened up to a threaded plate other than to lock the plate off.
Many thanks, Mark.
trevorhp
Has thanked: 16 times
Re: early seatbelt mount oriantation
Post by trevorhp »
Stops the plate jiggling round and damaging the paint surface ;)
Its also an FIA requirement for racecar belts :)
KDK 320F
HDK 443E
DJJ 226H
TFD 47G
PKV 375
1 x chassis 007 1967 Cox GTM
Mark1Peachey
Cheers Trevor always good to confirm my thoughts.
Mark,
On my 60 there is a 1/4 UNF bolt that goes into the smaller hole to stop the plate twisting.
You probably know that, thought I'd point it out just in case ;)
Mark1Peachey
Hello Andrew,
Strangely that smaller hole isn't treaded and there wasn't a bolt in it when I stripped the car but it does make sense to have one there, thanks for letting me know.
Mark
No worries Mark
Nut and bolt required as they aren’t threaded as you rightly say :)
