servo repair kit
servo repair kit
Anyone knows the part number for the Lockheed servo? the early one ,as used on MK1 Cooper s.
Cheers Cpr1
Cheers Cpr1
- Been thanked: 55 times
Re: servo repair kit
This company claim they have the early MK1 S rebuild kits'
https://www.ebay.co.uk/itm/SSB1036-NEW- ... Swb2JbiObv
- Has thanked: 18 times
- Been thanked: 51 times
I seem to recall that a company in North Cornwall makes batches once in a while, and probably supplies both companies.
I am disappointed that the seller does not post to the United States.
I have MK 1 brake servos that I would like to restore but need the seal kits to accomplish the task.
Jim
Jim
- TECH396
Thank you for the information to deal direct.
I will contact them tomorrow and hopefully they will post to the USA
Jim
Jim
- Has thanked: 4 times
- Been thanked: 9 times
You can also check Alfa Romeo parts suppliers, the 105 series Alfas used the same servo that built under license by Bonaldi (later Bendix/Benditalia). The rebuild kits aren't cheap though, and you want to be sure the bore of the main servo body is fit for purpose, quite often if they've been sat for a while the aluminium bodies are too badly oxidised for use.
Same goes for any steel ones like the originals of course, a first check would be that the bores are nice and clear of rust and scoring - then temporarily reseal them with red brake grease
Retro minis website is still showing complete Bendix units btw
http://www.retrominisltd.co.uk/index.ph ... cts_id=132
