Mini Moke cage nut
Charlynsane
Mini Moke cage nut
Post by Charlynsane »
Hello Guys
I'm currently restoring a moke mk1
I'm looking for these sort of nuts that hold the grab handle
Does anyone knows where I could find it?
thank you
Has thanked: 188 times
Been thanked: 66 times
Re: Mini Moke cage nut
They are a bit of an odd one and to the best of my knowledge, they didn't use them in the Mini.
Have you tried M-Parts ? Bodge here on the forum (when he's about) would likely know.
geroch
Post by geroch »
are not the same as the mk1/2 door check strap ?
1/4” unf bolt...
As spider says well, ask m-part or m-machine.
geroch wrote: Tue Jun 02, 2020 7:23 pm are not the same as the mk1/2 door check strap ?
1/4” unf bolt...
These are 5/16" UNF.
I'll have to have a closer look at the Door Check Strap all the same. Ta.
I could do with one of these too.
Has thanked: 18 times
Been thanked: 51 times
Here's a better pic of the door strap ones before a repair Spider. Similar but smaller I think?
woodypup59
Has thanked: 8 times
Been thanked: 22 times
Post by woodypup59 »
Very similar to the captive nuts in the seat cross member for the seat brackets.
If you have access to a lathe, you could turn some up, cut the end to make the ears and crimp them in.
But that might need a hefty crimper !
Thanks for the pic Andy - that's the type but wrong size.
Our locally made cars just had a strip of metal with tapped holes here.
Hipwell
Post by Hipwell »
T Nuts are similar, but are spot welded, though this looks more like a type of press nut
Charlynsane
Hello Guys
I managed to find another area where it's fitted on a mini
The sill reinforcement bracket
If I buy the spare is it possible to remove it and to install it on my Moke?
I think they are 3/8 UNC Charles
Will check later this evening as fitted these to HOY
Just checked and they are 3/8 UNC
Might be worth speaking to Doreen at MiniMachine though as they may be able to source them or make some 5/16 UNF ones for you.
Pandora
Post by Pandora »
For a relatively low impact part such as a grab handle, would a rivnut suffice for ease?
Al
Charlynsane
Thank you guys
Yes I could put a Rivnut but I would be as close as possible from the original species of the car
Is it possible to remove it from a spare?
Oneball
Has thanked: 10 times
Post by Oneball »
Would these work? Flange might be too small.
https://www.moss-europe.co.uk/anchor-bu ... xx140.html
Charlynsane
Hello
Yes actually it will works, but not original as the cage nut
I'm still waiting for M machine answer.. finger crossed
Charles, always best to telephone Doreen at MiniMachine ;)
Much as I am a great fan of M-Machine. MokeParts will be a much better bet for this.
http://www.m-parts.co.uk/
