Radiator upper bracket and fan blade
I just replaced mine radiator, upper and lower bracket and housing for a 67 Cooper S. The previous owner used a mk2 housing and how it modify to fit. Now that I’m using the correct parts, the upper bracket for housing is higher and shorter, close to an inch than the thermostat housing using part 12G0617. So I order #12G0617S and a spacer #12A0312 from Seven Mini parts because the fan blade is rubbing the outer housing. Would these two parts solve issue.
Thank, Thai Hon
- Been thanked: 55 times
Re: Radiator upper bracket and fan blade
Hi,
If you could add some pictures ...this would help the Forum shed some light on your problem...just a thought!
