12 G 1505 crank
woodypup59
Has thanked: 8 times
Been thanked: 22 times
12 G 1505 crank
Post by woodypup59 »
Just pulling a 1275 engine apart and can see the crank has 12 G 1505 moulded in the forging. The conrods seem to have very big caps too. No pictures a t m. Can't see any cam markings apart from a pink (?) dot.
Googling suggests the following.
12G1505* - 1275cc - Non-S, EN16T with 1.75" dia. big ends
* 12G1683 - 1275cc - 12G1505 forging, non-S, EN16T with 1.75" dia. big ends, Tuftrided
So its a steel crank with large big ends.
Does that and the hefty big ends mean its a bit racy ?
I'm not very familiar with this large bore stuff so forgive the scant details.
GraemeC
Re: 12 G 1505 crank
Post by GraemeC »
Standard A-series 1275 crank (non-S) as used in 1275GT, ADO16 1300 etc.
Has fillet radii on big-ends meaning it can be stroked and then used with 1.625” rods
65MK1S
Re: 12 G 1505 crank
Post by 65MK1S »
My 12G1505 (AEG623) crank has 2.00" mains and 1.625 rods
Has thanked: 189 times
Been thanked: 68 times
Re: 12 G 1505 crank
Might need a photo here so we all can be 100% sure.
My lists show this crank was fitted in 2 styles. 1 was fitted to the early 1300 series of engines up to about 68-ish (and I'm guessing this is what you have) and the other to the later Cooper S in Tuftrided form.
As 65MKIS suggested, I have the Mains lists at 2.00" and the Big Ends at 1.625".
It would have the 1275 Midget type Con Rods.
65MK1S
Re: 12 G 1505 crank
Post by 65MK1S »
Yep, my rods are AEG521's
GraemeC
Re: 12 G 1505 crank
Post by GraemeC »
If it was an AEG623 it would be stamped as such wouldn’t it?
65MK1S
Re: 12 G 1505 crank
Post by 65MK1S »
Yeah, mine's stamped AEG623 right over the top of the 12G1505
woodypup59
Re: 12 G 1505 crank
I will get some photos tomorrow and hopefully look at the hefty con rods.
Thorp
Re: 12 G 1505 crank
Post by Thorp »
As GraemeC has already stated, this sounds like a standard 1300 Crank.
The 12g1505 forging was also machined (and stamped up) for other applications, with the 1.625” journals as above and also there was a tuftrided version of it used in the 1300gt. This has the 12g1505 ground off and 12G1817 stamped over the top in the same way as the Crank above.
251 ENG
Re: 12 G 1505 crank
Post by 251 ENG »
The mk3 cooper s crank AEG 623 is made out of a 1505 forging , just machined differently to the srd 1300 crank .
Differences are
Cooper s big ends
BMC cross drilling
Cooper s centre main thrust width
It is then tuftrided
There are also crankshaft shafts modified from other forgings used in early ADO 16,s fitted with 1300 engines with cooper s rods
But that's a hole other story
woodypup59
Re: 12 G 1505 crank
Heres a picture of the crank with markings and the ( to me anyway ) hefty big end cap.
Is this a standard non-S 1275 bottom end ?
All comments welcome.
Thorp
Re: 12 G 1505 crank
Post by Thorp »
Yes, standard non S bottom end. That type of rod is perfectly serviceable, but heavy.
Re: 12 G 1505 crank
This is what it is;-
GraemeC wrote: Sun May 24, 2020 5:02 pm Standard A-series 1275 crank (non-S) as used in 1275GT, ADO16 1300 etc.
and I've updated my own list !
The Rods on them are OK but can be lightened a long way. Depending on what you're doing with the engine, you may wish to consider tracking down some A+ Rods for it.
Costafortune
Has thanked: 32 times
Been thanked: 38 times
Re: 12 G 1505 crank
Post by Costafortune »
Early transverse 1275's as fitted to VdP 1100's as an option from 1965 used an EN16T crank with S rods and journals. I think a few had the proper S crank.
