Bottom hose.
36inter
Bottom hose.
Post by 36inter »
Hi,
I would like a bottom hose that is 32mm bore, in reality I just want the top bend with the heater take off, any ideas, thanks.
Pete
Has thanked: 188 times
Been thanked: 67 times
Re: Bottom hose.
If nothing else shows up, you can get 'bolt in' adaptors, that you can fit in to a manufactured bend. You put a timber in the hose, punch the hole, the neater, the better, then fit the adaptor. Depending how they are made, some slip on from the inside, with a plate, and another plate and nut go on the outside.
There is at least one supply of the bottom hoses who does them this way.
36inter
Re: Bottom hose.
Post by 36inter »
My previous post disappeared. 🤦‍♀️
Thanks Spider, I will look into that, looking at some other options too, I will let you know what happens.
Pete
Re: Bottom hose.
Cheers Pete.
I also just now recall Mackay's have an on line listing. Might need a bit or trawling, you might find what you're after
https://9198c40c-83e9-4d43-bf42-8056bee ... 01053b.pdf
while they don't list here, specific vehicles these hoses fit, only their own Part Numbers, it would be possible to track down what cars they are used on from that.
Chris
36inter
Re: Bottom hose.
Post by 36inter »
Hello Chris,
Thanks, thats an interesting site, not seen that one before.
I sat and looked at what I was trying to do, gave it some real thought before going half cocked. I have an ally tube between the first and second 90 deg hose, with just enough space to weld an outlet to, so thats what I did. I machined up an ally outlet and welded it to the tube. Actually its not welding, ally brazing would be a more accurate term, I use HTS 2000 , brilliant stuff, when I can sort the photos I will post them.
Thanks again for your help.
Pete
