Mistery Input Gear
LuisM
Mistery Input Gear
Post by LuisM »
Hello,
anyone would recognize this input gear, without holes for the locktab washer ? never seen one...
This is similar to a 4 synchro 24 teeth... got it along with a ADO16 casing .
How would the 1st motion shaft nut would be locked ?!
Luis
iain1967s
Re: Mistery Input Gear
Post by iain1967s »
Loctite on the threads? Or maybe with a castellated locktab similar to what’s used on the output pinion to secure it on the mainshaft?
Has thanked: 188 times
Been thanked: 68 times
It does appear to have an ever so slightly different tooth profile.
Only a guess here, but I'd wonder if it came out of JKD.
LuisM
Post by LuisM »
loctite could be an option, the castellated locktab i believe would not fit as the slots in the 1st motion shaft would need to protrude from face of the input gear and another type of nut used.
The teeth edge are definitely different, i've just checked if this could be from a spanish built gearbox but no, these also use input gears with holes for the locktab.
Ok i'll remain curious :)
Thanks All!
Luis
whistler
Has thanked: 18 times
Post by whistler »
Ask John Guess if he's come across this type of gear.
Tim Harber
Been thanked: 14 times
Post by Tim Harber »
Not JKD I think. I have an .916 Economy gear from them which used to be the mod to get longer gearing on an A series box and it shows fairly proper marking and holes
ImageJKD Economy gear by tim.harber, on Flickr
I don't know what these are off though. Same spec as Mini but posh end covers
ImageOutput shafts by tim.harber, on Flickr
and finally , what is this off ? Its a standard looking bonnet catch assembly but with an extra plate welded on. Part number doesn't seem to appear anywhere I can find. Just sold it to someone who didn't want or care about the extra bit in any case...
ImageCZH3173 bracket a by tim.harber, on Flickr
ImageCZH3173 bracket by tim.harber, on Flickr
roymck
Post by roymck »
The output shafts are 59 mini parts . Grease nipples with no rubber gaiter .
8662 FN Austin Mini
Yes I know it’s not original
LuisM
Post by LuisM »
exactly , my 59 car has them!
That bonnet catch is nice, the pad should help releasing it and opening the bonnet.
Luis
bwaminispeed
Post by bwaminispeed »
I believe the odd hood latch is for Canadian export with smog pump.......
The pump, with it's pulley sits very high, and, very far forward, right about exactly where the bonnet latch is........would be easy to poke your fingers into the pulley, this plate prevents that......
Did smogged cars show up in England, or, were they just an export thing???
Tim Harber
Thanks for answers. It figures on bonnet catch
No smogged up cars here or ugly spud Canadian bumpers. The one thing that used to turn up here was Canadian Mk3 doors particularly on Clubman Estates . I remember scrapping them and finding they had some sort of side impact bars in them which meant they were stronger than UK ones. I assume the factory got stuck with them and put them on to get rid of
Alex
Post by Alex »
The bonnet catch looks to be Canadian Mini spec, and if you'd consider parting with it I'd be VERY interested - my unique UK market Canadian-spec Mini will need a bonnet one day...
