washer pump
Posted: Sun Mar 22, 2020 3:46 pm
by WesleyB
Hi,
i have instal a new washer pump, because I was think the old didn't good work
But if I try it I don't work ? Isn't this good ? Is there a good alternative that you don't see ?
Re: washer pump
Posted: Sun Mar 22, 2020 5:01 pm
by Quinlan minor
Have you removed it from the car?
If not, pull the hose from the jets, they may be blocked, and check if water is pumped.
If nothing, leave jets disconnected and remove pipe from pump. Blow through to check pipe isn't blocked.
If removed already, fit hoses to the pump and immerse them in a bowl of water, connect it to a battery and see if it works.
Re: washer pump
Posted: Sun Mar 22, 2020 11:13 pm
by WesleyB
my old one is in the car, the tubes are good but it don't work. It's like it don't have enough power to put the water up.
Also I have a new from mini spares, I put this in a bowl water, but also there it don't work ?
Re: washer pump
Posted: Sun Mar 22, 2020 11:26 pm
by bwaminispeed
Re: washer pump
Posted: Sun Mar 22, 2020 11:30 pm
by WesleyB
ok, now you say, the foot valve, I must look for that.
Re: washer pump
Posted: Mon Mar 23, 2020 4:36 am
by Aussie Bill B
http://www.minispares.com/product/Class ... windscreen washer.aspx|Back to search
"bwaminispeed" is saying you need to have a 1-way valve in the water bottle so the water can only go up the tube to the pump, then to the screen.
Sometimes, these 1-way valves have a spring that is too strong for the pump and they do not let the pump work.
Re: washer pump
Posted: Fri Mar 27, 2020 4:45 am
by Tim
Sometimes they have a one way valve in the T-piece that splits the single line from the pump to go to the two jets. Its just a ball bearing in there.
Re: washer pump
Posted: Fri Mar 27, 2020 7:23 am
by Herbert
In using that type of pump, you musthave a non-return valve that fits inside the water bottle. Part number GWW506. If you dont have it all it will do is blow bubbles in the bottle !!!
