washer pump
WesleyB
Has thanked: 7 times
washer pump
Post by WesleyB »
Hi,
i have instal a new washer pump, because I was think the old didn't good work
But if I try it I don't work ? Isn't this good ? Is there a good alternative that you don't see ?
MK1 Austin Cooper 998cc 1967 Smoke Grey
http://mk1-forum.net/viewtopic.php?f=6&t=26813
Quinlan minor
Re: washer pump
Post by Quinlan minor »
Have you removed it from the car?
If not, pull the hose from the jets, they may be blocked, and check if water is pumped.
If nothing, leave jets disconnected and remove pipe from pump. Blow through to check pipe isn't blocked.
If removed already, fit hoses to the pump and immerse them in a bowl of water, connect it to a battery and see if it works.
WesleyB
Re: washer pump
Post by WesleyB »
my old one is in the car, the tubes are good but it don't work. It's like it don't have enough power to put the water up.
Also I have a new from mini spares, I put this in a bowl water, but also there it don't work ?
bwaminispeed
Re: washer pump
Post by bwaminispeed »
it needs a foot valve to work, it's just an open bellows by itself........It just pumps air in and out of both tubes at the same time......
Foot valve is at the end of the hose in the bottom of the washer bottle........That hose needs to be hooked up to either tube on the pump.....
Love the hook it up to a battery suggestion........Funniest thing I've heard in years :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
WesleyB
Re: washer pump
Post by WesleyB »
ok, now you say, the foot valve, I must look for that.
Aussie Bill B
Re: washer pump
Post by Aussie Bill B »
http://www.minispares.com/product/Class ... windscreen washer.aspx|Back to search
"bwaminispeed" is saying you need to have a 1-way valve in the water bottle so the water can only go up the tube to the pump, then to the screen.
Sometimes, these 1-way valves have a spring that is too strong for the pump and they do not let the pump work.
Tim
Has thanked: 4 times
Been thanked: 22 times
Re: washer pump
Post by Tim »
Sometimes they have a one way valve in the T-piece that splits the single line from the pump to go to the two jets. Its just a ball bearing in there.
Tim
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
Herbert
Re: washer pump
Post by Herbert »
In using that type of pump, you musthave a non-return valve that fits inside the water bottle. Part number GWW506. If you dont have it all it will do is blow bubbles in the bottle !!!
