22A108 FLYWHEEL HOUSING
Can anyone confirm if the 22a108 housing can be used with a remote 4 synchro box?
Re: 22A108 FLYWHEEL HOUSING
Pretty sure the clutch/flywheel housing isn't 3-4 syncro specific........
More important, is the 1st motion shaft support bearing hole, the earlier 3 syncro ones were a bit smaller I think.....
That’s a very early flywheel housing. The first motion shaft bearing remained the same through out. As long as you are not using it for an A plus type box it will work. The later housings refined and improved the shrouding of the oil throw and the delivery of oil to the bearings , also made provision for a breather. There were many iterations.
