Help - Overheating
JonsINNO
Help - Overheating
Post by JonsINNO »
My 1975 Inno is constantly overheating. Can someone provide advice? Do I change out the radiator, the fan? Any ideas would be appreciated.
Jon
Has thanked: 18 times
Been thanked: 51 times
Re: Help - Overheating
Could be a number of things but if it was sudden, my first thought would be to ask if you have checked the head gasket??
rolesyboy
Has thanked: 19 times
Post by rolesyboy »
Hi, assuming there is nothing more immediately apparent have you got the yellow cooling fan the right way round? (It is labelled as such on the face of the fan)Easy mistake to make but the orientation is critical in maintaining temperature.
Cheers. Mark
roymck
Post by roymck »
Do the easybits first, check thermostat and check hoses , I had a top hose delaminate and it made a internal flap that stopped water flow . Run it from cold and look in radiator with cap off to see what’s going on .
8662 FN Austin Mini
Yes I know it’s not original
